No connection at all with UI7 [solved]
I’ve upgraded my VeraLite to UI7.
Now I can not make any connection with Homewave to my unit.
What has changed and how can I connect again with Homewave to my VeraLite?
Regards,
Floris
Did you check settings?
I don’t know what the settings should be for UI7.
With UI5 it ws working fine.
You must change setting for Ui7.
i → vera → ui5 = off
I did.
Didn’t help.
Btw, connecting via home.getvera.com or another app without problem.
Just via HomeWave isn’t working.
I’ve deleted the app from my iPad.
Then reinstall and let HomeWave find my VeraLite.
Now it is working again.
