I apologize for my newbe-ness to Vera.
I have a Vera3 and have several time installed and reinstalled the dataMine plugin. Every time it does not detect any channels.
I have a 1 GB USB drive installed. It is formatted fat32. Below is a dump of the dataMine debug page.
Thanks in advance for your help.
-1-===========================================================================
09 09/14/13 19:34:57.959 JobHandler_LuaUPnP::Run device 11 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0x940848 upnp: 0 <0x2af25000>
50 09/14/13 19:35:02.920 luup_log:11: dataMine: Initialising dataMine System (0.980) <0x2b859680>
06 09/14/13 19:35:02.920 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: false now: false #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b859680>
06 09/14/13 19:35:02.921 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9a34d0/NONE duplicate:1 <0x2b859680>
06 09/14/13 19:35:02.921 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b859680>
50 09/14/13 19:35:02.921 luup_log:11: dataMine: Mounting to UUID ‘2EFA-15FC’ <0x2b859680>
50 09/14/13 19:35:03.364 luup_log:11: dataMine: UUID = /dev/sda1: LABEL=“LOG” UUID=“2EFA-15FC” <0x2b859680>
50 09/14/13 19:35:03.380 luup_log:11: dataMine: Found UUID ‘2EFA-15FC’ at ‘/dev/sda1’ <0x2b859680>
50 09/14/13 19:35:03.421 luup_log:11: dataMine: Error reading tmpfile during mountcheck <0x2b859680>
06 09/14/13 19:35:03.422 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: /dev/sda1 now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b859680>
06 09/14/13 19:35:03.422 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: vfat now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b859680>
50 09/14/13 19:35:03.438 luup_log:11: dataMine: Mounting dataMine storage (/dev/sda1) to (/dataMine/) <0x2b859680>
50 09/14/13 19:35:03.486 luup_log:11: dataMine: Mounted: /dev/sda1 on /dataMine type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) <0x2b859680>
06 09/14/13 19:35:03.487 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: now: /dev/sda1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b859680>
06 09/14/13 19:35:03.488 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: now: vfat #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b859680>
50 09/14/13 19:35:03.549 luup_log:11: dataMine: ERROR: Unable to open config file for read :: /dataMine/dataMineConfig.json <0x2b859680>
50 09/14/13 19:35:03.566 luup_log:11: dataMine: Primary config file load failed. No backup file found! <0x2b859680>
06 09/14/13 19:35:03.567 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9a34d0/NONE duplicate:1 <0x2b859680>
06 09/14/13 19:35:03.567 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b859680>
50 09/14/13 19:35:03.567 luup_log:11: dataMine: Reinitialising configuration structure <0x2b859680>
50 09/14/13 19:35:03.568 luup_log:11: dataMine: Startup complete <0x2b859680>
50 09/14/13 19:35:18.162 luup_log:11: dataMine: Delete backups complete - No files found <0x2c659680>
06 09/14/13 19:35:18.364 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskTotale[0m was: 998972 now: 998972 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c659680>
06 09/14/13 19:35:18.365 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskUsede[0m was: 1008 now: 1168 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c659680>
06 09/14/13 19:35:18.365 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskFreee[0m was: 997964 now: 997804 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c659680>
06 09/14/13 19:35:18.366 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskUsedPcnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c659680>
06 09/14/13 19:35:47.176 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9a34d0/NONE duplicate:1 LEAK this:86016 start:348160 to 0xc08000 <0x2c659680>
06 09/14/13 19:35:47.177 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c659680>
02 09/14/13 19:36:40.352 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download D_DataMine1.jsone[0m <0x2b486000>
02 09/14/13 19:36:40.353 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set D_DataMine1.jsone[0m <0x2b486000>
01 09/14/13 19:36:40.386 e[31;1mDevice_LuaUPnP::LoadDeviceDoc can’t load /etc/cmh-lu//D_DataMine1.xmle[0m <0x2b486000>
02 09/14/13 19:36:40.386 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_DataMine1.xmle[0m <0x2b486000>
01 09/14/13 19:36:40.387 e[31;1mJobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 11/D_DataMine1.xml so device 11 is offlinee[0m <0x2b486000>
09 09/14/13 19:36:46.278 JobHandler_LuaUPnP::Run device 11 room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xe61400 upnp: 0 <0x2b486000>
03 09/14/13 19:36:46.288 JobHandler_LuaUPnP::Run ready 11 devices installation 30006500 missing /etc/cmh-lu//D_DataMine1.xml version 1.5.622 allow_evt: 1 allow_ud: 1 upnp 0 netpnp: 1 reprovision: 0 tz:18000 tnow:1379201806 dst: 1 gmt:-14400 tz:EST / EDT changed: 0 pMem 0x107c000 start 14671872 diff: 2613248 <0x2b486000>
09 09/14/13 19:37:00.652 JobHandler_LuaUPnP::Run device 11 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0xaff370 upnp: 0 <0x2b0a7000>
50 09/14/13 19:37:05.355 luup_log:11: dataMine: Initialising dataMine System (0.980) <0x2b9db680>
06 09/14/13 19:37:05.355 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: EMPTY now: false #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.356 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetDataDirectorye[0m was: EMPTY now: /dataMine/ #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.356 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountUUIDe[0m was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.357 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountPointe[0m was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.357 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountOptionse[0m was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.358 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetManualMounte[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.359 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetTimeoutPeriode[0m was: EMPTY now: 12 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.359 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetHistoryEnablee[0m was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.360 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetUseBackupe[0m was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.360 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetEventsEnablee[0m was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.361 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 v:0xb621d0/NONE duplicate:0 <0x2b9db680>
06 09/14/13 19:37:05.362 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b9db680>
50 09/14/13 19:37:05.362 luup_log:11: dataMine: Installing update of dataMine web application <0x2b9db680>
50 09/14/13 19:37:10.062 luup_log:11: dataMine: ERROR: Startup state is ‘uninitialised’! <0x2b9db680>
06 09/14/13 19:37:10.062 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0xb621d0/NONE duplicate:1 <0x2b9db680>
06 09/14/13 19:37:10.063 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2b9db680>
50 09/14/13 19:37:10.063 luup_log:11: dataMine: Reinitialising configuration structure <0x2b9db680>
50 09/14/13 19:37:10.064 luup_log:11: dataMine: Startup complete <0x2b9db680>
50 09/14/13 19:37:25.225 luup_log:11: dataMine: Delete backups complete - No files found <0x2c7db680>
06 09/14/13 19:37:25.258 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskTotale[0m was: EMPTY now: 998972 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c7db680>
06 09/14/13 19:37:25.259 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskUsede[0m was: EMPTY now: 1180 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c7db680>
06 09/14/13 19:37:25.260 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskFreee[0m was: EMPTY now: 997792 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c7db680>
06 09/14/13 19:37:25.261 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mdiskUsedPcnte[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c7db680>
06 09/14/13 19:37:54.312 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountUUIDe[0m was: now: 2EFA-15FC #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 LEAK this:4096 start:327680 to 0xdc1000 <0x2dbdb680>
09 09/14/13 19:38:12.535 JobHandler_LuaUPnP::Run device 11 dataMine graphing and logging room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 id parent 0/0x961268 upnp: 0 <0x2ba65000>
50 09/14/13 19:38:17.292 luup_log:11: dataMine: Initialising dataMine System (0.980) <0x2c199680>
06 09/14/13 19:38:17.292 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: false now: false #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c199680>
06 09/14/13 19:38:17.293 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9c3fd8/NONE duplicate:1 <0x2c199680>
06 09/14/13 19:38:17.293 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c199680>
50 09/14/13 19:38:17.294 luup_log:11: dataMine: Mounting to UUID ‘2EFA-15FC’ <0x2c199680>
50 09/14/13 19:38:17.681 luup_log:11: dataMine: UUID = /dev/sda1: LABEL=“LOG” UUID=“2EFA-15FC” <0x2c199680>
50 09/14/13 19:38:17.697 luup_log:11: dataMine: Found UUID ‘2EFA-15FC’ at ‘/dev/sda1’ <0x2c199680>
50 09/14/13 19:38:17.720 luup_log:11: dataMine: Mounted: /dev/sda1 on /dataMine type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) <0x2c199680>
06 09/14/13 19:38:17.721 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountLocatione[0m was: EMPTY now: /dev/sda1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c199680>
06 09/14/13 19:38:17.722 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mmountTypee[0m was: EMPTY now: vfat #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c199680>
06 09/14/13 19:38:17.786 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:0x9c3fd8/NONE duplicate:1 <0x2c199680>
06 09/14/13 19:38:17.786 Device_Variable::m_szValue_set device: 11 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2c199680>
50 09/14/13 19:38:17.787 luup_log:11: dataMine: Startup complete <0x2c199680>
-2-===========================================================================
-3-===========================================================================
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,noatime,mode=600)
/dev/mtdblock7 on /overlay type jffs2 (rw,noatime)
overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
/dev/mtdblock8 on /mios type squashfs (ro,relatime)
none on /proc/bus/usb type usbfs (rw,relatime)
-4-===========================================================================
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table
Disk /dev/sda: 1024 MB, 1024966656 bytes
255 heads, 63 sectors/track, 124 cylinders
Device Boot Start End Blocks Id System
/dev/sda1 1 125 1000943 b Win95 FAT32
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(1023, 254, 63) logical=(0, 0, 3)
Partition 1 has different physical/logical endings:
phys=(1023, 254, 63) logical=(124, 155, 63)
-5-===========================================================================
SetDataDirectory-/dataMine/
SetMountUUID -2EFA-15FC
SetMountPoint -
SetManualMount -0
-6-===========================================================================
{“Version”:“0.980”,“dbVersion”:2,“Events”:{“count”:29,“last”:1379175021},“guiConfig”:[],“Variables”:[],“Graphs”:[],“LastWrite”:1379201747,“nextId”:1}
-7-===========================================================================
