Hi All,
I’m pulling my hair out and could do with a bit of help pls.
I’m new to my Vera edge and have decided to skip scenes and go straight to the Programme Logic plugins.
However, I can’t complete my first piece of logic as nothing is showing the the “actions” drop down. I’ve got as far as doing a complete factory restore and re-installing PLEG, but nothing is working (so I think it could be user error).
What am I doing wrong??? I’d love to know as I’m not sure where to turn next?!?.. Here’s my logic:
Between sunset and and midnight, I want it to turn on a z-wave plug powering the fairly lights on the front of the house.
Here’s what i’ve done:
- The z-wave plug is setup as a device and I can control it via an on / off device switch with no issues.
- I’ve created a new PLEG device
- I’ve created a new schedule “s1_is_it_dark” it run from Mon to Sun, from sunset to 23:59
- I’ve created a basic condition of “c1_is_dark”, which I assume will trigger whenever the above schedule is true
I then thought the final step would be to select the z-wave plug as an action in the dropdown in the actions tab, but there is nothing there??? It’s just an empty drop-down list… Have I missed something as I don’t know what to do now??? I thought it might be the plug that wasn’t working, so I have also tried creating a virtual switch, but that isn’t showing as an action either.
Any help would be hugely appreciated…
Thanks in advance
Casper.
Sounds like you started just fine!
It’s always best to attach a PDF of the output of the Status command from your PLEG.
I am not sure I follow where you are having problems.
When you select the Actions tab your condition will be one of two places.
- In the DropDown list with a label of: “Add Actions for Condition:”
Which will add it to the table on that tab.
- Already in the table on that tab.
Then you select the edit to add actions for a selected condition.
I think I might have cracked it… amazing what a clear head and being told you’re on the right track will do.
my issue was that in the Actions page, I thought all the actions would be listed in the “add action for condition” dropdown.
Instead, it seems I need to into “Edit” and then select the “Immediate” option, where I can then add devices, either as “advanced” or “control”.
So, hopefully all sorted now
One final quick question if I may, I’ve set my schedule to run from sunset to 23:59 to turn of the Christmas tree. Does that mean that 00:00 the tree will turn itself off. OR, so I need to create another schedule that shuts down the light at midnight?
Casp.
Set one schedule sSunsetTo2359.
Condition 1- sSunsetTo2359. Action: Turn on the lights
Condition 2- !sSunsetTo2359. Action: Turn off the lights
Condition 2 uses the same schedule but the ! means “not”. So Condition 1 looks to see if the schedule is true and thus turns on the lights. Condition 2 looks to see if the schedule is false and if so turns them off.
