[quote=“kwieto, post:20, topic:199145”]Not sure what you mean by"exact setup"? Vera Plus firmware 1.7.3831, alt UI ver 2.26.
How to access java script console log?
In my browser ctrl+j opens side bar with favorites
It worked couple of days ago with the same settings, the only change can be (not sure) upgrade of altUI to newest version[/quote]
CTRL f5 for chrome , not sure for?other Browsers, it should be in their doc for opening the JavaScript console log.
Do you use multi controller ?
What are altui variables value (cf http://wiki.micasaverde.com/index.php/Luup_Requests#status) ?
You may try to go in ui7 settings for altui and press the reset button also.
Are you sure? Ctrl+f5 refreshes data, Ctrl+J opens a tab with downloaded files
I’ve found shourtcut Ctrl+Shift+I, below what I see after clicking it
jsapi?autoload={"modules":[{"name":"visualization","version":"1","packages":["gauge","table"]}]}:22 A parser-blocking, cross site (i.e. different eTLD+1) script, https://www.google.com/uds/api/visualization/1.0/40ff64b1d9d6b3213524485974f36cc0/format+pl,default+pl,ui+pl,table+pl,gauge+pl.I.js, is invoked via document.write. The network request for this script MAY be blocked by the browser in this or a future page load due to poor network connectivity. If blocked in this page load, it will be confirmed in a subsequent console message. See https://www.chromestatus.com/feature/5718547946799104 for more details.
google.loader.f @ jsapi?autoload={"modules":[{"name":"visualization","version":"1","packages":["gauge","table"]}]}:22
J_ALTUI_multibox.js:221 controller Main did not respond. disabling it
J_ALTUI_multibox.js:909 Uncaught TypeError: Cannot read property 'controller' of undefined
at Object.getBoxInfo (J_ALTUI_multibox.js:909)
at _refreshFooter (J_ALTUI_uimgr.js:4445)
at Object.signal (J_ALTUI_uimgr.js:14934)
at Object.<anonymous> (J_ALTUI_utils.js:2501)
at Function.each (jquery.min.js:2)
at Object._publishEvent [as publishEvent] (J_ALTUI_utils.js:2499)
at _AllLoaded (J_ALTUI_multibox.js:149)
at J_ALTUI_multibox.js:228
at u (jquery.min.js:2)
at Object.fireWith [as resolveWith] (jquery.min.js:2)
J_ALTUI_multibox.js:798 Uncaught TypeError: Cannot read property 'controller' of undefined
at Object._getFileContent [as getFileContent] (J_ALTUI_multibox.js:798)
at Object._getFileContent [as getFileContent] (J_ALTUI_utils.js:4047)
at Object._updateDeviceTypeUPnpDB [as updateDeviceTypeUPnpDB] (J_ALTUI_multibox.js:76)
at Object.<anonymous> (J_ALTUI_verabox.js:1762)
at _loadUserData (J_ALTUI_verabox.js:1758)
at J_ALTUI_verabox.js:1815
at J_ALTUI_verabox.js:1136
at Object._unproxifyResult [as unproxifyResult] (J_ALTUI_upnp.js:39)
at Object.<anonymous> (J_ALTUI_verabox.js:1134)
at Object._refreshFooter [as refreshFooter] (J_ALTUI_uimgr.js:4445)
at J_ALTUI_uimgr.js:14834
at dispatch (jquery.min.js:2)
at y.handle (jquery.min.js:2)
22J_ALTUI_multibox.js:909 Uncaught TypeError: Cannot read property 'controller' of undefined
Can’t execute these commands remotely. Local controller works fine
Can’t execute these commands remotely. Local controller works fine[/quote]
ok, main controller did not respond fast enough hence the message
then it does not like to have no controller to work with …
I ll see how to put this timer in a variable that you could fine tune in your case. for now, revert to previous version ( use the release tag in github to get the version you want )
or you can play with line 209 of J_ALTUI_Multibox.js and increase the 2000 value by something bigger ( it is in millisec ) until it works.
I am curious what is the good value
[quote=“Tsviper, post:16, topic:199145”][quote=“svaleb, post:15, topic:199145”]As Tsviper says it cannot be empty so I replased it with his suggestion.
“id=lr_ALTUI_Handler&command=home”
And it seems to work fine.
But what is the correct text ?
Thanks for all help !!![/quote]
It seems a lua reload changes the link from vera back to the one that does not work.
So what to do next ?
I ended up going into the AtlUI interface and deleting the variable and just restarting Luup like amg0 suggested. It then recreated the variable with the correct info. See attached screenshot.[/quote]
This is the one I use for now http://192.168.1.10/port_3480/data_request?id=lr_ALTUI_Handler&command=home#
and it works.
I open from vera where it says “open”. BUT if I make a luuop reload it is reset in vera to the old one wich does not work.
And sometimes it is neccesary to make a reload in vera (read: often).
I followed your advice and set it in in altui. I get the short message “waiting for initial data” but it works. Right now I do not get the 404 message, I think I will if I reload.
