Nexus 7
The old guy wants to know how to get this great App on a Nexus 7. Play Store will not show it.
Thanks for all the great help
Showed up find on mine. Search for “AutHomation HD”…
Hugh
HUGH … not on my playstore ??? Try search for aut & aut HD.
It shows up for me. However the nexus 7 does not display the layout as a normal tablet but a combination of the tablet and phone. I will need to tweak the layout for the app to display correctly. Do a search for AutHomationHD in the play store. It should show up.
  • Garrett
@grybrd,
Try the direct link:
https://play.google.com/store/apps/details?id=com.garrettpower.authomationhd
[quote=“hugheaves, post:5, topic:172125”]@grybrd,
https://play.google.com/store/apps/details?id=com.garrettpower.authomationhd[/quote]
Thanks for posting a direct link. Let me know if you experience any issues. I need to work on the layout to fit the device properly. I’m hoping to get version 2.1 out soon. Running into some issues with new features being added.
Will also need to exchange my nexus 7 due to the screen lifting issue on the left side. Mine is pretty bad.
  • Garrett
Garrettwp … left hand screen thing …quite a few fixes on our Nexus forum.
Tried tightening the screws with no luck. The screen is several millimeters above the silver bezel. It’s pretty bad.
  • Garrett
Thanks guys for the link! Working rather well.
Having just received my Nexus 7, I installed it and it works fantastic so far, much, much better than the free Vera app on iOS. Thanks!
works nicely on mine but had some trouble finding it in the store too
Not sure why. I know if you search for authomation, it should show up. I’ve made some changes to have the layout work better on the 7 inch screen. I have to work out some bugs that seems to appear in jelly bean.
  • Garrett
[quote=“garrettwp, post:12, topic:172125”]Not sure why. I know if you search for authomation, it should show up. I’ve made some changes to have the layout work better on the 7 inch screen. I have to work out some bugs that seems to appear in jelly bean.
  • Garrett[/quote]
    On my nexus 7, in the playstore, if I put in everything except the “HD” (or any partial) it doesnt come up and asks “did you mean automation”
HD is there … it is the same one from the above link. Once again thanks for a great app!
I’ve always had difficulty searching for this app on any device. I’ve had to put in the exact name to get it to show up. Authomation isn’t even enough if you need Authomation HD. No idea why, I’ve never put an app on the store before. Is there a way to add meta tags or something?
I believe this was brought up awhile back in the android community. Google has a tendency to not like words that are not spelled correctly. There were a few articles that explained this. You could always search for vera or home automation. It may be lower in the list as it does not have as many downloads as some of the other apps.
  • Garrett
I search for micasaverde
