Next version in development (1.0)
Here are the current changes compared to the beta 3:
[ul][li]
Fix: switch light device not created for a smoke sensor (KD101/SA30)
[/li]
[li]
Fix for OWL CM180 and CM180i: total usage is not always provided by the RFXtrx
[/li]
[li]
Support added for Alecto WS1700 and compatibles sensors
[/li]
[li]
Support added for Alecto WS4500, Auriol H13726, Hama EWS1500, Meteoscan W155/W160, Ventus WS155 sensors
[/li]
[li]
UI tab RFXtrx settings: minor position adjustments
[/li]
[li]
Minor change to set the variable CommFailure to 0 only when current value is not 0
[/li]
[li]
Plugin icon stored locally
[/li]
[li]
New variable “RFYMode” available for RFY to select between standard mode (value “STANDARD”), venetian US mode (value “VENETIAN_US”) or venetian EU mode (value “VENETIAN_EU”)
[/li]
[li]
UI: “Change angle + (Venetian US)” command available for RFY in the “Managed devices” tab
[/li]
[li]
UI: “Change angle - (Venetian US)” command available for RFY in the “Managed devices” tab
[/li]
[li]
UI: “Change angle + (Venetian EU)” command available for RFY in the “Managed devices” tab
[/li]
[li]
UI: “Change angle - (Venetian EU)” command available for RFY in the “Managed devices” tab
[/li]
[li]
UI: “Enable sun/wind detector” command available for RFY in the “Managed devices” tab
[/li]
[li]
UI: “Disable sun detector” command available for RFY in the “Managed devices” tab
[/li][/ul]
The icon (PNG file) has to be uploaded in this directory: /www/cmh/skins/default/icons
This version is available in trunk directory. It could evolve at any time.
Thanks for the update, I will give it a try when I find the time.
Sorry lolodomo, I completely forgot about this. Just updated the few files that was changed. I’ll let you know if I run in to any troubles. I’m still on UI5 btw.
New features added:
[ul][li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li][/ul]
For RFYMode variable, use one of these values: STANDARD, VENETIAN_US or VENETIAN_EU.
New changes:
[ul][li]
[/li]
[li]
[/li]
[li]
[/li][/ul]
I am trying the trunk code on my VeraEdge now. Seems to work. Just figured I have to create all the dimmable devices from scratch to be able to dim them. I first tried to auto create the ones I had on a remote but they where only possible to switch on or off, no dimming.
As usual, the new device is created as a switch if you sent an On/Off command. Just go in the advanced tab to change the device type.
Or send directly a DIM command at the first step if you can to create directly a dimmable device.
Sorry I cannot see the link to download the plugin files anywhere. I found the link for the beta 3, but not for the updated files for 1.0 (I only need the updated owl files as I am on 1.0 already)
I know its probably very obvious somewhere and I am just not seeing it…
http://code.mios.com/trac/mios_rfxtrx/browser/trunk
[quote=“lolodomo, post:8, topic:186529”]As usual, the new device is created as a switch if you sent an On/Off command. Just go in the advanced tab to change the device type.
Or send directly a DIM command at the first step if you can to create directly a dimmable device.[/quote]
Thanks, is it enough to change the “device_type” value. What about device_file and device_jason?
[quote=“lolodomo, post:4, topic:186529”]New features added:
[ul][li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li][/ul][/quote]
Can you tell me how can I run those commands in a luup code? I would like to be able to enable/disable the sun/wind detector with a scene.
Thanks in advance.
[quote=“hyzteric, post:12, topic:186529”][quote=“lolodomo, post:4, topic:186529”]New features added:
[ul][li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li]
[li]
[/li][/ul][/quote]
Thanks in advance.[/quote]
You can try luup.call_action(“urn:upnp-rfxcom-com:serviceId:rfxtrx1”, “SendCommand”, {DeviceId=xxx, CommandType=“cmd”}, mainId)
with cmd amongst VENETIAN_US_ANGLE_PLUS, VENETIAN_US_ANGLE_MINUS, VENETIAN_EU_ANGLE_PLUS, VENETIAN_EU_ANGLE_MINUS, ENABLE_DETECTOR, DISABLE_DETECTOR, … and xxx being the device id of your window covering device.
mainId is the device id of your RFXtrx main device.
Thanks it’s working :smiley:
luup.call_action("urn:upnp-rfxcom-com:serviceId:rfxtrx1", "SendCommand", {DeviceId=55, CommandType="ENABLE_DETECTOR"}, 41) luup.call_action("urn:upnp-rfxcom-com:serviceId:rfxtrx1", "SendCommand", {DeviceId=55, CommandType="DISABLE_DETECTOR"}, 41)
I first tried with mainid = window covering device id, it also worked.
Anyways, thank you ! :slight_smile:
You’re right, it should work too because action is then inherited by the parent device.
I have a question.
When I click on a switch in the Vera UI7 webinterface (from a 433Mhz device) the light turns on right away BUT the circling of the “hour glass” runs for about 15 seconds. During that time the webinterface does noet respond/cannot be used.
However, When I click on the off or on button in the “control” tab the webinterface can be used right away.
Do you know what causes this? This only is the case with 433Mhz modules.
[quote=“TwannieM”]I have a question.
Do you know what causes this? This only is the case with 433Mhz modules.[/quote]
I have that too but have mostly used rfxcom stuff. Kind of annoying.
[quote=“strips, post:17, topic:186529”][quote=“TwannieM”]I have a question.
I have that too but have mostly used rfxcom stuff. Kind of annoying.[/quote]
When I tested the plugin with UI7 6 months ago, I noticed something similar. It was reported to the forum even if I don’t find my message today.
I assume it is a UI7 bug … or feature !
Maybe it has to do with the fact the 433Mhz plugin reporting back the state after such a long time? Or not reporting at all?
Here is my message: http://forum.micasaverde.com/index.php/topic,26785.msg198239.html#msg198239
