[quote=“Hackworth, post:360, topic:186853”]@rlmalisz Absolutely, once I’m home. In the meantime, I’ve been poking around for other people with the issue and they’re suggesting one of your devices is causing it to die. I’ve got two ideas, one you could look at your http://IPADDRESS:51826/accessories file (after running it through a json formatter service) and see if anything looks wrong, for instance a value is outside a min or max value. The second is you could git checkout 15d263 which is the commit right before I converted this to bridge mode, then go add every device individually and note which fails to add.
Also, do you have window coverings or garage doors?[/quote]
Can do, it may be a day or two before I get it done.
Yes on garage doors, using the garage door plugin. And yes on window coverings, but they’re being controlled as dimmable lights via a plugin I wrote myself. They’re Hunter Douglas, so they actually report position and can have position set explicitly, so the window covering Vera interface was underwhelming.
