Newbie questions
Vera lite and RFXCOM arrived today!
Apolgies for the basic questions.
I’ve had a good look and can’t find the answer.
How do i upload luup files?
Do I do it via the vera lite interface?
via winscp? if so is there a root login? where do the files go?
Once uploapded is there anything i need to run?
Thanks in advance.
On the Vera interface, go to apps, develop apps, luup files. There you can upload them.
You will have to read the instructions which come with the luup files, (most threads on here which have luup files attached tell you what you need to do) some want to you to tick restart luup after upload, but you should reload your interface and browser anyway to show the new devices you created
