Newbie needs some help
Hi there, I am a newbie here. Actually, I’m not even a newbie yet! I am looking into getting into a bit of home automation. I already have a Schlage Z-Wave door lock that I bought basically for the keypad functionality at the time. Since it is Z-Wave I am thinking of going with the MiCasa Verde Lite for a controller. Once I have that I will have control of my front door.
From there I want to start adding a few things. But I’m not looking for anything too complicated. I have no interest in automating my entire home and creating scenes, etc… I just want to be able to control alarm, door lock, thermostat, and a couple lights while away traveling for work.
The lights seem pretty easy via some simple light switches or plug in modules. Anything I’m missing there?
The thermostat also seems pretty easy…just replace my current thermostat with a Z-Wave thermostat (Trane, Honeywell, etc…). Now I see when I look at some of those thermoststas that they say they require a monthly fee for remote control. Does that go away when controlled by the MiCasa Verde Lite? Or are only certain thermostats compatible?
Finally, the alarm! This seems to be the most complicated…if even possible. I currently have a hard wired alarm system that covers all doors/windows on the first floor. It was installed when the house was built in 1996 and is controlled by a First Alert panel (model FA215). Is it possible to just switch this panel out, maybe for a DSC panel? If so, could this then be controlled by the MiCasa Verde Lite, and thus remotely from the app when travelling?
Thanks so much in advance for any help anyone can offer. I just don’t want to jump into this if its not what I need.
Thanks!
You will be able to do all that with Vera … No monthly fees.
I recommend a Trane/RCS Z-Wave thermostat. Some like the NEST Theromstat. It connects via Wifi to Vera via the Nest Servers. (Vera <-> Nest Servers <-> Thermostat).
Also the DSC can be connected to Vera for self monitoring … And if you want, you can ALSO connect to a Monitoring Service.
Door/Motion sensors in your DSC alarm system can be used in your Vera Automation.
If you have wired sensors … they will probably all work with DSC. If you have any wireless sensors … they may be an issue.
Thanks so much for the quick reply! I think I am ready to jump into this. I was just looking at the Trane/RCS TZ45 theremostat. But I see it is wireless, and I know my current theremostat is wired to the HVAC system. Is there an option for that?
It’s not wireless to the HVAC.
Ya looking back that was a silly question, sorry about that. I did a little more research and it looks like the TZ43 or TZ45 could both work for me. Its strange, the TZ45 isn’t even listed on the RCS website, only the TZ16, TZ40, and TZ43.
I am also new to Vera. Just purchased my unit two weeks ago. I have been researching thermostats for a while and like the RCS units the most. What I like about them is the ability to direct connect temperature sensors to the thermostat. This will let me locate all the thermostats in one location out of view of the living area and away from the kids bedrooms. Secondly this will allow the thermostat to operate the HVAC system based on temperatures sampled in two different locations independent of Vera. Then I can use Vera for temperature setbacks based on schedule and house scene and humidity control based on z-wave sensors.
From what I can tell, the TZ45 is a direct replacement for the TZ43. I cannot identify any difference in features, just appears to be a difference body. Must have been a supplier or patent issue (speculation).
