I am currently building a new home that will be completed in about 1 month. I currently have a Wink, 4 Cree light bulbs, the remaining lights switches, ceiling fans, thermostat and Linear garage door control will be Z-Wave and will likely add a Vera Edge as my primary hub with the Wink Connect App to controle lightbulbs. My question is it possible to use a mini mote z-wave remote to controle the Cree Connect Zigbee bulbs with Verra as the go between?
I tried this usind the wink plugin for the wink and ge link bulbs but found there was too much of (30+ second) a delay.
Sent from my SAMSUNG-SM-N915A using Tapatalk
Though I’ve never done it since I don;t use Wink, this should be perfectly possible. A Vera scene that sends commands to the Wink controller. The Minimote activates the Vera scene. There should be little or no delay.
