New WiFi network
Hello,
I have a Vera 3 that i recently upgraded to UI6. Since then, a new WiFi network called Vera_30106XXX shows up in my list of available networks.
What is it?
I never enabled WiFi on my Vera, i use a wired connection. How can i turn it off?
Thank you in advance,
/Mike
It is the internal Vera3 Wifi and it enabled by default.
It use the password under the unit. Goto setup Net/wifi, change from Automatic to Manual Configure and scroll to the bottom and you can turn it off.
