Hallo everyone,
i´m new to Vera2 (and this forum). First sorry for my english, i´m german but i´ll give my best
I have a lot of things in Vera which does not what i expect to.
Ok, i´ll give you an short overview what seems to be ok and what not.
Things they LOOK ok (but i don´t know if it is really ok)…
- After including Vera in my Networkstructure (all three lights are solid on: Power, ETH1 and zwave)
- “Login” to vera (respectively mios.com) seems ok and vera could be found by mios.com. Later, after forwarding to 192.168.0.102/cmh/ i see the vera Webinterface and that i´ve been logged in. I´m also listed as Administrator in MYMIOS.
- Setting up, changing and viewing of “LOCATION” seems ok; all things what i´ve setup will be listet here.
- Advanced-Tab:
->Tech-Support
->Net & Wi-fi
->Backup
->Firmware
All these seems to be ok for me.
- Tech-Support could be enabled and shows up Informations.
- Netsettings are set to “Through another gateway on my network. Vera is a switch” and the informations about “IP address”, “Subnet mask”, “Gateway” and “DNS” are correct. It must be correct cause vera2 could connect to mios.com for login, checking firmwareversion and so on.
- Wi-Fi settings seems to be ok too; i can see the SSID “vera_31743” in my Mobilephone
- Backup-Tab lets me view my backups, making new Backups, let me restore backups.
- Firmware-Tabs shows up the following informations:
Testing connection to: download1.mios.com … OK
You are running the latest version: 1.5.255 . - When putting vera in include-Mode veras Lights are blinking in described way. They blink once per second while in include-mode and they flicker when i push the include-button on my zwave-components. I have TWO here to test; one Motion Sensor and one Appliance Module.
All fine till here but, sadly that i have to say this, that´s it. ALL Other funtionality seems NOT to be ok.
Things they look NOT to be OK
- When i pint to 192.168.0.102 in my browser i would be forwarded to 192.168.0.102/wizard/ and there i get an “404 - Not Found”-Error.
ALL Tabs inside of “MIOS DEVELOPER” are Empty and showing “No room”. No LUAs are listet or can be set or viewed. Nothing.
ALL Tabs inside of “Z-WAVE DEVICE” showing only “No room”. None of the included Z-Wave-components are shows up here.
Additional Informations
I have installed “Home Buddy” to my Android-Cellphone and setup Veras IP and so on. I i have a look in Home Buddy on my “Devices” the two i have included are listed under “Global”.
- “_Appliance Module”, Status: off (it can be set to OFF and ON and on the module itself the Status-LED showing me that it is ON or OFF.
- “_Motion Sensor”, Armed: no. Ican can be Set to armed: Yes and No. My motion sensor did not have an Status-led so i cannot verify the Status.
Last but not least i´ll give you some Screenshot (Please find them Attached)
