New to Vera - Purchased ABMHZ but needs motor?
Hey everyone,
I am new to Vera but loving it! I wanted to put some motorized shades/curtains in my house since it should help me save on cooling (ridiculous heat coming in from the sun) but I think I made a mistake. I purchased a ABMHZ Z-wave motor control thinking that was all I needed but it appears to literally just be a controller. I tried looking up motors and browsing through this forum but haven’t seen anything relating to what I bought. Also, I will move in 3 years so any solution needs to be easy to take down and take with me when I leave…
Product link: [url=http://www.elec-solutions.com/products/z-wave/abmhz.html]Page Not Found
You purchased correctly, the Z-Wave motor controller will work with any 4-wire dumb AC tubular motor with internal limits from any manufacturer (Somfy, Elero, Motion Control, ESI, etc.). If you order your roller shades from a fabricator you just need to ask for standard dumb motors and see if they are available in a quiet version.
Thanks for the reply Shady, I wanted to PM you but can’t yet :frowning:
Before I noticed your post, I purchased the universal Motor Interface Control Kit from RollerTrol: http://rollertrol.com/store/en/motor-control-kits-for-home-automation-systems/58-home-automation-systems-motor-control-starter-kit.html
It is a DC motor and doesn’t appear to be directly linkable to Vera (doesn’t have its own zwave module). Looks like I need to either purchase a new motor or the DBMZ. Do you know if multiple motors can connect to the DBMZ? I would like to purchase one for a room and connect two shades to it (to save $)
we offer a motor module, Z-Wave to dry contact.
Shows as a shade motor on Vera, has 3 outputs open/stop/close you can solder to an existing transmitter, or connect to dry contact input of anything with relays… Needs to be powered 12-24VDC
info@zwavemotors.com
