Hello, so I’m new to the alarm world and I need help I just had a Vivint system installed and hate it so I going to have it ripped out asap but I need a system to put in its place. My cousin has Vera running his whole house but there is no central mo monitoring with his system and I really what that feature, my question is way alarm package can I install myself that would be able to talk to Vera and give me central monitoring capabilities? My house came with an alarm system that uses z-wave window and door sensors so I would love to keep them since they still work well( Vivint is currently using them). I would also love to have a screen live Vivint uses to run as much of the system as possible, I will be adding cameras and lighting controls and hopefully at some point amazin echo to run the whole house. I will be doing the install myself and would like a system that is extremely user friendly. I really appreciate and help anyone can give me. Also while I’m asking what security cameras will work best and but still give ma excellent resolution.
Hi Gary. We talked on the phone today.
Your Z-Wave door and window sensors as far as I know will not work with a dedicated alarm panel such as our DSC systems. Can you verify that the sensors are indeed Z-Wave or a similar frequency like these that are dedicated for alarm systems. http://www.discoverecolink.com/pro-security/
As you can see they make different sensors for alarm panels vs Z-Wave and different sensors for different makes of alarm panels.
I would be surprised if an alarm panel was using Z-Wave sensors.
What make is your current alarm, prior to the Vivnt?
If you decide to go with the DSC + Envisalink + Vera, which is what I suggested to you, you can check them out here.
You can also check our tablets and wall mounts here.
I hope this helps. Please ask if you have any more questions.
