Welcome!
Personally I’m on UI5 with no intention to change that. If I have a spare GE remote, I could give it a try on a test system with UI7. But hopefully someone else has tested this with UI6.
Welcome!
I have a GE 45600 remote and I was able to create a scene within the Vera and pair it back to the remote (it was pretty hard but thanks to those who created great instructions).
I now have a slight problem because my Lutron Duplex Receptacle is separated quite a distance away from the Vera. When I take the GE remote and go close to the Lutron, it can turn it on and off. When I’m close to the Vera, the Vera doesn’t respond to the remote and it doesn’t relay the message to the Lutron. I’ve tried repairing the mesh. Am I doing something wrong here? Are controllers able to communicate directly with the Vera?
How have you gotten the GE (JASCO) 45600 remote to work as a scene controller with Vera?
I’ve tried all of your instructions. I read this forum from beginning to end.
I’ve tried all of these instructions…
http://wiki.micasaverde.com/index.php/GE_Advanced_Remote_45601
And my own concoction here…
http://www.amazon.com/review/R1BTNN7XP5JX6Z/ref=cm_cr_rdp_perm
All I’ve ever gotten to function is the ALL > Any-number-ON/OFF feature. Pressing SCENE > Some-Number-ON/OFF does NOT function. The scenes never transfer to the remote. As near as I can tell, the first time the remote is paired, it attempts a scene transfer. Why, I don’t know, because the remote is brand new to the controller, and so there would never be any scenes to transfer. Then, when I actually put it into some scenes, and re-pair it, there’s never a message indicating that it’s even trying to transfer scenes to it. I’ve tried everything I can think of, and become exasperated and very frustrated.
I have VeraLite with UI7 on firmware 1.7.388. Again, I have the GE (JASCO) 45600 (not the 45601).
I’m about ready to chuck this thing into the basement cabinet of no return, but I thought I’d give it one last chance to reach out to someone who has claimed to have gotten it to work. Can anyone help?
I’m adding my n00b $0.02 here as well. I have a Vera Lite with UI7 1.7.439. I have two z-wave remote controllers: a JASCO 45600, and an Intermatic HA07. I have tried to pair both of them and have the same problem as described in this thread. I can pair the devices (as secondary controllers, I guess?), configure the number of buttons, and assign scenes to buttons. I attempt to re-pair the devices (send programming to the remote from the Vera?) and get no “detected” type of response from the UI. The blue status banner displays Please wait…, then Add/Remove: Transferring scenes, then Add new devices now… and there it sits. The all on/off commands work, but not the scene buttons. The scene buttons don’t respond with a green blink that would indicate that they are sending the scene command that they were programmed for. I assume this means that Vera can’t program the devices (transfer the scene commands?) during the re-pair attempt. Is this a universal programming function for all z-wave secondary controllers and UI7 simply can’t do it? Does anyone have any z-wave remote (not an android or ios app, just a simple z-wave controller) working with UI7?
I too have the same symptoms. I have Vera 3 and UI7 1.7.439. It can’t complete the 2nd pair to educate the remote.
After calling support, they said to submit a trouble ticket. So we’ll see how long it takes for them to get back to me. If it’s too long I’ll request to have my unit downgraded back to UI5.
same problem here - vera lite finds my GE 45600, I add the scenes, but I can’t push the programming back to the remote (i.e. the green light doesn’t light up when I push “SCENE” and then the number.
Me too. I strongly recommend folks stay away from these remotes.
I’m considering purchasing the GE 45600, do people still feel the same way about this device? Has anyone tried with the latest version of Vera code?
I have a Vere Edge with the latest Firmware installed (1.7.1181) and the GE 45600 handheld controller doesn’t work at all.
After days and days of trying different methods, finally I found a workaround for this remote and it works perfect for me. This is how I did:
Principle: You need to use VERA controller to create the scenes and transfer them to the GE 45600 Remote control, after this, the GE Remote Control will execute the scenes bypassing the VERA as a Scene Controller.
At this point the GE control is already programmed and should work both sides of the buttons (ON and OFF).
I had a problem with mine and is that when I pressed a button to activate a Scene, another scenes activated as well at the same time. In order to fix that what I did was:
With this procedure I finally did put my Remote Control to work as it supposed to work.
Hopw this helps you guys.
I can make the remote work with UI5. There has been a few new releases of UI7. I don’t want to waste my time upgrading to UI7 if this doesn’t work. Anyone try the latest UI7 with this remote yet?
I have added a GE remote 46500 to my veralite as a generic scene controller but cannot turn on or off my lamp modules from my remote, the only way to turn lamp modules on and off is to press the all button and then of course they are all on or all off. The only way I have found that will control individual lights on and off is to transfer primary control to my remote using (shift controller function) after I did that I was able to program individual buttons to individual lights, however now that I have my remote as the primary controller, I cannot add another lamp module to vera. Does anyone know how to transfer control back to the Veralite from the 46500 remote and if I do will it null and void my work??
caciagli
it did’t work for me.
Should be an easy way to do this with ui7. Why is it so hard?
Wow… after buying this remote and reading this whole thread, I’m definitely confused…
I ASSUMED (yeah… I know…) that the remote could just be used as triggers inside Vera… Just like I make a scene so when it becomes dark outside, it turns my porch lights on, I thought I could just set a scene to run when each button was pressed… Now I’m finding that it “kinda” works that way for the on buttons, but the off buttons have to talk directly to the zwave devices?! WHY? What if I wanted to include some extra logic, like, if I press the button to turn off something, it works differently at night, based on some other vera variable? Like, maybe at night, if I turn off the livingroom lights, maybe I want to turn the hallway lights to 10% to be a nightlight for me to walk to bed, and then turn off 2 minutes later? I want the Vera to be the hub for everything… at least I THINK I do, unless someone explains to me why that’s not good??
Is there a remote out there that someone could recommend that would just be a portable battery operated device that would just let me trigger different scenes through vera, without any possibility of controlling anything directly?
Thanks in advance!!
Steve
@172pilot: Sorry for the old thread reply… The MiniMote works amazingly for me – highly recommended.
I read through this thread since I am considering the purchase of the GE remote. I can see where the problem is because I have encountered it elsewhere with Vera. The analogy is that to a hammer, everything is a nail. To Vera, almost everything is a scene controller; even when the product is designed and sold as something else ? such as a zone controller. This particular remote “Controls up to 18 Zwave devices, groups or scenes.” It would seem that 1) too few people understand the difference between controlling devices, groups, and scenes, and 2) Vera cannot configure this device to provide the functionality for which it was designed. Also, what most of us want with this GE Remote is that it be a secondary controller (with Vera as the primary). That seems not possible (according to the GE device manual. it can be secondary only to another 45600, which would be primary.)
What I am looking for, and I suspect many others are as well, is a Z-Wave device that provides the same functionality as the X-10 HR12A PalmPad or the UR19A Remote ? i.e. a remote with on and off buttons that can be associated with specific Z-Wave devices (switches, dimmers, plug-ins, etc.) without having to add a kludge of scenes and virtual switches in Vera to make it all work. The GE 45600 ‘looks’ like that desired device, but it seems that it cannot easily be made to work as such with Vera.
The largest part of the controller is actually the spring-loaded clip that you use to clamp to the tripod handle I, too, have a Bogen. So, it really is more of a tripod oriented control than a hand-held control though it will so that fine as well. It also has a long cable I can measure if youd like.
