Did you put your day and night device id in the addons setting and just to be sure delete the useraddon micasaverde.addon, I notice that xbmc don’t like when you install new version without deinstall it. Let me know
@conchordian
Also try what you say on mac and windows, i delete the user data micasaverde.addon and open xbmc. Only put the vera ip and xbmcdevice id. restart the xbmc and put yes to the event. I didn’t receive any error and it was working. Could you give me more info on what you exactly done to debug it?
No, if you install the day and night plugin in the vera, and you want the event to be send only when vera is in the night mode put the device id of the day and night plugin and put the event at night. If you dont want it, leave it blank but make sure that the event is at yes not at night cause you will have a script error for sure. Let mew know.
[quote=“Mic, post:63, topic:174337”]@conchordian
Thanks[/quote]
I uninstalled the micasaverde.addon in xbmc, then deleted the \userdata settings.xml and deleted it from C:\Users\USERNAME\AppData\Roaming\XBMC\addons\packages.
I think I might have changed it to ‘night’ first before I went out of XBMC and found my day/night device id number, so it was probably that.
Ok, thanks. I add some notification when addon start so you know if it ok or not. Notification could be turn off in the addons setting. Will release it in short time and post it in the first post of the tread.
Hmmmmm!, spoke to soon! ; it just error’d as before even after an uninstall and reboot :-X
EDIT:
Worked now but only if I don’t reboot. The only other thing I can offer is that openelec XBMC raspberry draws high on the cpu ; like 95%+ - so it could be a timing/delay issue???
I don’t seem to get ‘music ended’ triggered anymore either. If I stop or pause fine, but if the track just runs too it’s natural end no trigger occurs. XBMC state still shows ‘audio start’
Might be related though to my random working/not working issue
It really strange, since i finish it, i use this version and never run in any problem. When you say you uninstall it, did you manually uninstall the micasaverde setting in the userdata? I know that im repeating that but you really must erase this folder. So there 2 folder for the addons, when you unninstall from the xbmc, the userdata micasaverde.addon stay there. Let me know?
Yep I uninstall the add-on and then remove user data. Still the same issue
I do notice on reboot sometimes it can take a while for me to ssh into the raspberry ; ie I get host refused connection down - presumably the ‘pi’ just isn’t ready yet. Not sure if your add-on needs ‘time’ or a connection which may not exist at that point? (would explain why an uninstall/reinstall (without reboot) might work)???
