Great plugin, works like a charm. Just a shame my sq connect does not allow me to show the gas usage
Edit… With the help of Huibs post I am able to send a mail at a certain time to receive the actual usage.
Would it be possible to send a weekly mail which compares the value of date1 and date2 and tells me the usage of that week.
I would love to get a weekly mail with my usage that week.
Made some small changes for users who produce their own energy eg with with solar systems. Only file edited is “I_dutchSmartMeter.xml”.
Changes:
Edited – Check current watts section –
Renamed this section to – Check current watts import –
Added comments for documentation (and my own understanding of the code ;D)
Logging messages extended with word Import to make a difference with the added section by me
Added Section – Check current watts export –
This section has the same structure as – Check current watts import –
Produced watts have minus mark (-) in front of the number as suggested by robvanbrunschot
The root device will show the actual usage or production
having read this topic and since i have a vera lite since november 2012 and a dutch smartmeter since 2-1-2012 i ordered a serial cable on ebay (antratek does not have it in stock)
I already have my alarm system hooked up on serial so i hope a second cable on usb hub will work.
Is there a way to get a extra meter for gas as a separate device ?
@bfromdruten : Works perfect!!! Really happy with it. Tried to sent you a message, but i can’t. If you sent me a message to info@robbshop.nl I have something for u as a thank you (if you want, no obligations).
I have attached a photo of the - value (so my solarpanels are producing more than my usage)
Would be possible that you create a separate gas meter just like the 4 separate power meters?
Now the standard meter (actual use, tariff and gas) doesn’t show anything on mobile apps.
@cmbeek or others who might know:
Ive got the smartmeter installed today and cable works like a charm…except the gas meter.
Any idea what to do (I see you had the same problem… what solved it?)
Thanks guys!
@druw I am not sure what solved it…
But it started working after asking my electricity company (greenchoice) why my smartmetersettings were not showing on their website. I guess they changed some settings which also resulted in showing gasmetervalues in the vera plugin…
Sorry, I can not help you with a more specific solution.
Wow, you are quick:)
Ive called Liander (network service) and the meter wasnt in their system yet (duh).
It seems that the meter values need to be pulled one time by them remotely in order to let the electricity meter and the gasmeter connect (and keep connected).
Since its RF, I hope it won’t mess with my RFXCOM which is 2 meters up from the gas meter;)
If it doesnt work in I week, I need to call back…
Thanks for the direct response and for others: keep this in mind when you also receive a seperate gas and electricity meter which are not connected by cable…
(I wonder how the gasmeter receives power for his operation…)
How can I check that the P1 is sending any data at all?? I am not receiving anything, and the tool FT PROG does not seem to be able to display the current data.
I have attached a photo on how I connected it. I used a standard RJ11 cable, and used the red, black and yellow cable. I have put the blank ends into the black plug of the FTDI 5v USB converter.
I connected the USB cable to my netbook and I configured the chip to reverse the RX. I use Putty to monitor the COM-port but I am not seeing ANY data…
finaly its working , two usb serial cable’s later (one 8 weeks waiting ebay china 7 euro and a dutch cable one dag waiting 25 euro).
The cable was not the problem.
Its was the meter. The meterman came removed the seal. plugt-in a connector (intern). place the cover back. did make a new seal.
And It did work like a charm.
The Dutch Smart Meter is not working with the envoy sun pannels.
the dutch smart meter stays on 10 Watt
and the export stays on 0 Watt
the total count of al meters increased as expected
What is wrong in my settings?
this what i found in the log file:
50 02/02/13 16:11:38.254 luup_log:117: Meter data (not processed): “0-0:17.0.0(999*A)” <0x2e85d680>
50 02/02/13 16:11:38.274 luup_log:117: Meter data (not processed): “0-0:96.3.10(1)” <0x2e85d680>
50 02/02/13 16:11:38.294 luup_log:117: Meter data (not processed): “0-0:96.13.1()” <0x2e85d680>
50 02/02/13 16:11:38.304 luup_log:117: Meter data (not processed): “0-0:96.13.0()” <0x2e85d680>
50 02/02/13 16:11:38.354 luup_log:117: Meter data (not processed): “0-1:96.1.0(3238303131303038323332303533313132)” <0x2e85d680>
50 02/02/13 16:11:38.374 luup_log:117: Meter data (not processed): “0-1:24.1.0(03)” <0x2e85d680>
50 02/02/13 16:11:38.424 luup_log:117: Gas meter reading in next line <0x2e85d680>
50 02/02/13 16:11:38.444 luup_log:117: Gas meter: [00709.601] <0x2e85d680>
06 02/02/13 16:11:38.445 Device_Variable::m_szValue_set device: 117 service: urn:brutgrink-com:serviceId:dutchSmartMeter variable: ctrl_chr[35;1mGasctrl_chr[0m was: 709.601 now: 709.601 #hooks: 1 upnp: 0 v:0xfd48e0/NONE duplicate:1 <0x2e85d680>
50 02/02/13 16:11:38.454 luup_log:117: Meter data (not processed): “0-1:24.4.0(1)” <0x2e85d680>
50 02/02/13 16:11:38.464 luup_log:117: Meter data (not processed): “!” <0x2e85d680>
Has somebody expiriences with reading a P1 from a Stedin ZCF120ABd? I’ve spending three days now and finally I think the problem is in the meter ???. I’ve tried it with a FTDI cable and a CMOS interface circuit, but on the Request input I read zero ?A while connected and while not connected the request port reads an infinite impedance. When connected the data output is continious low (about 0,2V) sinking >10mA dependent of the pull up resistor. Do I need a pull restistor on the data output? In my opinion it is an open collector output. The P1 companion standard stated a typical 5mA input current for the request line. Can somebody confirm to me that the request input current is about 5mA, then i know for sure that the fault is in the meter. TIA
