As a start you should look first at the template json file
http://192.168.81.1/cgi-bin/cmh/get_json.sh?file=template_data.json
Then have a look at the java script that generates the web pages: /www/cmh/js/scripts.js
The you’ll need to know also that Zensys publish default devices categories, but manufacturers can create custom devices according to the zwave classes published by Zensys ( a device can report itself as a sensor but can be a thermostat according to zwave classes ).
So a manufacturer can create an 3-in-1 device that can’t be put in a single category and for that we ask that device what command classes it knows and we split it in 3 different categories (in your browser you see it as 3 devices but in the zwave it is only one device).
[code]int ZWaveNode::GetDeviceTemplate(unsigned char cGeneric,unsigned char cSpecific)
switch(cGeneric)
case GENERIC_TYPE_SWITCH_MULTILEVEL:
if( cSpecific==SPECIFIC_TYPE_MOTOR_MULTIPOSITION )
return DEVICETEMPLATE_Drapes_Switch_CONST;
else
return DEVICETEMPLATE_Light_Switch_dimmable_CONST;
case GENERIC_TYPE_SWITCH_BINARY:
return DEVICETEMPLATE_Light_Switch_onoff_CONST;
case GENERIC_TYPE_WINDOW_COVERING:
case GENERIC_TYPE_SENSOR_BINARY:
return DEVICETEMPLATE_Motion_Detector_CONST;
case GENERIC_TYPE_SENSOR_MULTILEVEL:
return DEVICETEMPLATE_Generic_Input_Ouput_CONST;
case GENERIC_TYPE_THERMOSTAT:
return DEVICETEMPLATE_Standard_Thermostat_CONST;
case GENERIC_TYPE_ENTRY_CONTROL:
return DEVICETEMPLATE_Door_Lock_CONST;
case GENERIC_TYPE_SWITCH_REMOTE:
return DEVICE[/code]
Devices that need to be treated in a custom way:
int ZWaveNode::CustomDeviceTemplate(int iManufacturer, int iProductType, int iProduct)
if( iManufacturer==ZWAVE_MFR_RYHERD_VENTURES && iProductType==2 && iProduct==1 /* 3-in-one-sensor */) // todo , this is repeated above
return DEVICETEMPLATE_Express_Controls_EZ_Motion_CONST;
else if( iManufacturer==ZWAVE_MFR_EVERSPRING2 && iProductType==258 && iProduct==1 ) // Everspring door/window sensor
return DEVICETEMPLATE_Door_Sensor_CONST;
else if( iManufacturer==ZWAVE_MFR_DUEWI && iProductType==16385 && iProduct==0) // todo this is repeated in CustomDeviceTemplate
else if( iManufacturer==ZWAVE_MFR_DANFOSS && iProductType==100 && iProduct==1) // todo this is repeated in CustomDeviceTemplate
The above is a snipped from our zwave code so you’ll have an idea on how we identify the devices and assign then in a category.
4/5. Arm/Disarm are internal commands. They are used only for creating a scene that has an event which reacts only when the sensor it’s armed. The Zwave device doesn’t know about this, so that it why you send the command to the Security Pluggin and you see those parameter ids.
- The lock will ignore the level command. lock/unlock it’s as easy as using the on/off command.
