Just bought a FI8910W and hooked it up last night. Since there were so many posts about what equipment worked and didn’t, I figured I’d share my experience.
Purchased a new VeraLite and Foscam FI8910W on Tuesday, VeraLite was using UI6 and Foscam was using 11.37.52 Firmware. Set up VeraLite as per documentation.
Opened camera and then proceeded to set it up as per documentation:
- Connected to LAN via cable
- Enabled and connected to wireless from device manager
- Set static IP and new port for wireless connection (for an example, assume 192.168.1.100 and port 2000)
- Setup port forwarding on router, to forward traffic on port 2000 to 192.168.1.100. Verified on canyouseeme.org that it worked
- Enabled manufacturer’s dynamic dns on the cameras device manager.
- Verified that I could log in to the camera by going to 192.168.1.100:2000 and also by going to the manufacturer’s dynamic dns page. Both worked. Then I verified I could log in via the foscamp app on my Android. That worked as well and I could pan and tilt from both applications, very good responsiveness.
Then I logged into Vera to set it up on my system there. I was surprised to see that it had already been recognized without me doing anything, but it was listed as a VistaCam SD.
- Camera said “no image available” on the device page. Went into settings and updated the IP address to include the port (example, it was set to 192.168.1.100 and I changed it to 192.168.1.100:2000)
- This fixed the image on the device and I was able to see the camera image, but not pan or tilt.
- At this point I noticed that I was not able to log into the Foscam app on my android anymore and that I had been booted from the DDNS page on my browser. When I logged in with the default admin and blank password, it said “password incorrect”. I looked at the settings in Vera and noticed that it had automatically created a random password 2 fields under the regular camera password field (something like user, password, p2p, password). When I put this password into the DDNS page on my browser, it connected again and was able to pan and tilt from the browser. I was still unable to log into the Foscam app in my android though, with the default blank password or the new password.
- I then installed the Foscam 2.6 plugin in my vera. I was very skeptical that this would do anything, because I didn’t attach it to anything or issue it to a device.
- Before I tested this, and I’m mentioning because I’m not sure which relieved the issue, I also updated the web ui firmware and the hardware firmware for the camera.
After these last two steps I was able to pan and tilt from Vera, my browser, and the foscam phone app with no problems. Viewing and moving the camera on vera was also much more responsive (though still not as responsive as using the web browser or phone app).
I will update when I get more features to work, ie recording and motion sensor triggers, but I thought people that are looking to buy the camera and wonder if it’s compatible should not have any concerns. It’s a great camera and I was also very impressed by how well the night vision worked. I could easily make out the image when it was pitch black in the room.
