There’s a new ‘lite’ controller from Fibaro → http://www.vesternet.com/z-wave-fibaro-home-center-lite.
Difference between HCL and HC2 - the following has been extracted from Vesternet’s site.
The main differences between the Fibaro HCL and the HC2 are:
Plastic casing (HC2’s has an Alloy Case)
No LUA
No LiLi
No VOIP
Technical Details
Wireless: Z-Wave 868.42MHz
Antenna: External High Gain
Network Interface: 10/100/1000Base-T (Gigabit) Ethernet via RJ45 connector
Processor: ARM Cortex-A8 (720MHz)
WLAN: Connects to Wi-Fi Router via Ethernet cable
Power: 9-12VDC (Power Supply included)
LEDS: Power, Status, Ethernet, WLAN and Z-Wave
Dimensions (LxWxH): 90 x 90 x 33 mm
What can Vera learn from this for their next v4 release …
