New Dual-Band Dimmer KPL
In case anyone else gets one, I just received a new Dual-Band KPL dimmer.
It is Cat 1, Subcat 0x42. Currently, Altsteon doesn’t recognize it as a dimmer KPL, so I am working on adding that.
Replying to myself…
Initially I added the updates to the daemon, but not the LUA files. I have since added those.
That development build that will be dated “Fri Jul 12 00:0x:xx PDT 2013” will have the updates.
To update Vera, you will need to update:
  • Vera2 binaries or Vera3 binaries
  • I_InsteonPlm.xml
  • J_InsteonOptions.js
I also just purchased a Dimmer KPL however, it’s Cat 01 SubCat 41. Will this update work with my KPL also or will another update be necessary for Altsteon to recognize it as a KPL? Thanks.
Another update would be necessary.
I checked the Insteon category/subcategory list, and neither my KPL nor your’s are listed.
I can look at adding that tonight/this weekend.
Thank you very much for the help! Just to clarify, I would update from the nightly build… Lua files and alsteon_cli, altsteon files correct?
New changes were checked in to support the new KPL Dimmer subcat 0x41.
Please note, I have no way to test this out.
I will update this post once the development build is generated.
Thank you.
The development build is up. http://www.geektaco.info/altsteon/index.php
Built “Mon Aug 5 16:01:52 PDT 2013”
You will need to update
[ul][li]Vera2/3 binary[/li]
[li]I_InsteonPlm.xml[/li]
[li]J_InsteonOptions.js[/li][/ul]
Updated Vera 3 binary through ssh…uploaded I_InsteonPlm.xml and J_InsteonOptions.js through Luup files and still no luck. I deleted and added the KPL again with no success…
Did you reboot Vera? You need to restart the altsteon process somehow, since you updated the binary.
Did a reboot and restarted altsteon, KPL adds as a dimmer and main on/off works but still no scene controller. There is a “#2 scene controller” but I’m pretty sure it’s always been there. It doesn’t delete when I delete the KPL to re-add it.
Device number 2 scene controller is vera and can not be deleted.
  • Garrett
From the CLI, can you run the following command:<device> info and post the results?
Also, try the following a couple times each:<device> set_button_led_indiv 3 0 <device> set_button_led_indiv 3 1 and see if the button 3 turns on and off?
Cmd : 25.04.D3 info
25.04.D3:0007,00,FF,FF,FF - DevCat : FF SubCat : FF Ver : FF
Cmd : 25.04.D3 set_button_led_indiv 3 0
Unknown command ‘set_button_led_indiv’.
Cmd : 25.04.D3 set_button_led_indiv 3 1
Cmd :
Button 3 doesn’t respond when I run the command.
Try running the “poll” command. It looks like the device hasn’t responded at all. Are the PLM links on place?
<device> poll
Cmd : 25.04.D3 poll
25.04.D3:0023,02 - Executing forced poll.
25.04.D3:003D,02 - Device added. (0x01)
25.04.D3:0007,FF,01,41,43 - DevCat : 01 SubCat : 41 Ver : 43
25.04.D3:001C,02,02 - Insteon version 2.
25.04.D3:0024,02,00 - Light brightness is 0.
Cmd : 25.04.D3 on
25.04.D3:0008,02,FF - 25.04.D3 button/group 255 is on.
25.04.D3:0024,02,FF - Light brightness is 255.
25.04.D3:008D,00,01,00 - LED follow mask for button/group 1 is 0.
25.04.D3:008E,00,01,00 - LED off mask for button/group 1 is 0.
25.04.D3:008F,00,01,20 - X10 house code for button/group 1 is 32.
25.04.D3:0090,00,01,20 - X10 unit code for button/group 1 is
32.
25.04.D3:0091,00,01,1C - Ramp rate for button/group 1 is 28.
25.04.D3:0092,00,01,FE - On level for button/group 1 is 254.
25.04.D3:0093,00,01,05 - Global LED brightness for button/group 1 is 5.
25.04.D3:0094,00,01,00 - Associated non-toggle bitmap for
25.04.D3:0095,00,01,84 - LED state for button/group 1 is 132.
25.04.D3:0096,00,01,00 - X-10 all bitmap for button/group 1 is 0.
25.04.D3:0097,00,01,00 - Non-toggle bitmap for button/group 1 is 0.
25.04.D3:0098,00,01,00 - Trigger all-li
nk bitmap for button/group 1 is 0.
25.04.D3:003D,02 - Device added. (exists case)
25.04.D3:0007,00,01,41,43 - DevCat : 01 SubCat : 41 Ver : 43
25.04.D3:0024,02,FE - Light brightness is 254.
32.
25.04.D3:0095,00,01,85 - LED state for button/group 1 is 133.
25.04.D3:0095,02,03,81 - LED state for button 3 is 129.
32.
25.04.D3:0095,00,01,81 - LED state for button/group 1 is 129.
25.04.D3:0095,02,03,85 - LED state for button 3 is 133.
32.
Cmd :
Now it looks like the daemon knows that it is a KPL.
Does button 3 turn on and off its LED?
Reload LUUP now and see if the GUI detects it is a
Scene controller.
Yes the LED turned on and off. To reload LUUP am I just restarting the Vera?
Click the “Reload” button in the upper right of the webpage.
The KPL shows up with the On/Off which does operate the On/Off on the KPL. No scene controller in triggers is added.
