Networkable Relay/Sensor interface
Anyone out there using an IP-based relay/sensor interface? I’d like to wire anything related to home security I can, most specifically my garage door/sensor. I’ve seen a couple devices online, mostly a bit too pricy. Rather than using telnet/ipserial, I’d like to initiate the relays using a wget command from luup, and for sensor contacts, I’d prefer if the device could similarly initiate wget commands towards Vera. I’ll start calling manufacturers and finding the right product for my needs, but I’m curious if this is something someone has already got working in Vera.
