Hi ,
I plan to buy the netatmo weather station plus the rain gauge module .
Sounds like there is a specific version depending of your country due to the use of radio frequency between external modules and the main station itself .
Is this correct ?
Thank you
Yes this is correct:
“Wireless connection between modules:
915 MHz or 868 MHz long range 100m.”
Source → https://www.netatmo.com/press/es-ES/release/PR_NETATMO_UNVEIL_ES.pdf
I’m sure you already know this but there is a Vera Plugin for the Netatmo Weather station → http://forum.micasaverde.com/index.php/board,73.0.html
The plugin connects to the “Cloud” (i think), so the frequency should not matter.
+1 for Netatmo - it’s one of the most stable pieces of gear I have. Comm between modules is rock solid, Wifi on head unit is rock solid and the Vera plugin is rock solid
Ok Thanks a lot for the feedback.
This version of the main weather station " NWS01US " is saying that it is for US region = Fine
But the Rain module version “NRG01WW” is not clear about this .
I guess the Rain module supports both radio frequencies and that 915 Mhz is for US region ?
Btw , which 915/868Mhz protocol is used between the main station and the modules ?
Other question : Is it a problem that the closest weather station available can be far away so the weather data received by the Netatmostation can be a bit inaccurate ?
