Netatmo Urban Weather Station
Does anyone that uses HomeWave have a Netatmo Urban Weather Station? Does it have any incorporation with HomeWave at all?
Most of the sensors temperature, humidity, etc that use the standard upnp services should work with HomeWave. But for Pressure, Noise, and CO2 they might not be supported as they do not use a standard service and currently implement a generic sensor. Intveltr may have to add support for these in the app. However since they use a generic sensor and do not have a dedicated service name to these sensors, it would be best for the developer of the Netatmo plugin to agree on service names for these sensors so that 3rd party app developers can integrate them. I will not add them into my app until service names are agreed upon.
  • Garrett
I’m happy to update/extend the Netatmo plugin accordingly. There is no point in waiting for a wider resolution of this problem outside of this forum (if you actually want anything to happen.). There was a separate thread on defining such services, but no very recent discussion. Time to fire it up again, perhaps.
I would really like to have some action moved on that thread. At this rate, it may be wise to just use your service id for the sensors until a solution is worked out. But with activity moving along with the arduino plugin, I think standardization would be wiser.
  • Garrett
At the moment, HomeWave can display any value reported by any device, by using the Multi Value control. Keep in mind that for some stuff like pressure or CO2 levels, no unit will be displayed (or will be displayed as %)
