I’m using the Vera (“Orange”) plug-in for my Netatmo thermometer. Being a good American, my system is set to use Fahrenheit degrees. On the Device screen, the Netatmo devices report the temperature in Fahrenheit as expected. However if I set up a Device Property in PLEG for the Temperature from the outdoor module, the value is reported in degrees Celsius. It is very cumbersome to compare this value to other temperature values since they are in Fahrenheit and I have to do the math inside the PLEG condition.
Is there any way I can fix this? Would Vera support be able to help, or is this a PLEG issue?
