I developed a tool to generate some parts of the source code. As soon as I finish up a few minor touches in the tool, I am also planning to release that tool at Codeplex.
I have not used this C# API - however you might want to release a built EXE command-line wrapper for it (I realize not all use cases will fit neatly into a single commandline, perhaps figure out the 90/10 cases) also as part of your source, either as a C# console app or perhaps some sample PowerShell scripts - there are probably a lot of people who want to do some automation on Windows via CMD shell scripts but don’t know C# or want to get involved with the VS IDE. I haven’t searched extensively but I am not aware of any simple command-line interface on Windows (other than curl with URLs, other scripting langs, etc.)
Great DLL for Vera! I’m getting a parsing error when I call the Poll() method.
“An unhandled exception of type ‘Mios.MiosFormatException’ occurred in Mios.dll
Additional information: Could not parse returned value [1449.0790] to UInt32!”
Looking through my XML, I find:
I believe this is due to the precision level of data type UInt32.
You can of course type MiosConsole /? to get more information.
If you type MiosConsole it will continue to accept commands until you type exit.
Enjoy. Critiques, opinions, advice, info, bug details, are all welcome. It’s an open source world.
And… of course a HUGE thanks to Ercant who really did something impressive here. Exposing the API in an auto generated way along with some useful methods that really expose the Luup API as it is.
One thing Ercant. I’ve commented on codeplex in the discussion areas. I’ve run into a few bugs…
Mainly, that SCamera1 is sending a string back as “m” when it’s expecting something else.
Secondly, there’s another case where I’m seeing ‘floats’ or ‘doubles’ but it thinks it should be an UInt32. Please see the details. I’d like to get that fixed so I can use your core DLL instead of my revised version.
I try to use this lib.
I decide the problem with float ant int32.
But I have bigger problem.
I try to know status all binarylight switches:
[code]var miosData = new SummaryData(miosEngine);
foreach (MiosDevice element in miosData.Engine.Devices)
if (element.DeviceType == “urn:schemas-upnp-org:device:BinaryLight:1”)
var a = (BinaryLight1)element;
Console.WriteLine(String.Format(“Switch: {0}, {1}”, a.SSwitchPower1.Status, element.Name));
}[/code]
