Nest Plugin- WWN creates multiple devices
Hello.
Just starting out with this and began with my Nest. I was able to successfully authenticate it and it appears to be working fine. However, the WWN plugin adds multiple devices. A device for the actual Nest, a device listed as the Nest App, a home/away device and lastly, a humidity device. Is this correct? If so, is there a way to create a single device instead of having it spread across multiple devices?
I search around on the forums and via google but cant seem to find the answer. Any help would be great, or alternatively, direct me to a thread.
Thanks.
[quote=“Seaneee, post:1, topic:193563”]Hello.
Thanks.[/quote]
I have had the Nest thermostat for the last 3 years, and what you’ve got is exactly what appears with vera and is correct, there is no way to get a single device.
