Nest plugin changed celsius to fahrenheit today
My plugin today changed from C to F :o
i checked my vera edge is set to the right location and the weather location is set and the weather shows in degrees C but the plugin still only shows in F
i deleted and readded the device but still it won’t change back, any idea why ?
I don’t know, but I see that the new firmware update for VeraEdge is available to my unit. I am running 1.7.906 currently, and for the Ecobee plugin (I’m not running the Nest plugin on UI7), it’s showing F and the unit is set to F. If I see something similar to what you are describing after updating the firmware to 1.7.961, I will report back here.
watou
[quote=“deejc, post:1, topic:185972”]My plugin today changed from C to F :o
i deleted and readded the device but still it won’t change back, any idea why ?[/quote]
I just started experiencing the same issue. Any fixes?
