I have a Neo coolcam floodsensor z-wave plus but cant seem to get it working.
with fibaro i see all the options when adding a scene but with this i only see on and off.
is there a way to get this device fully working ?
Anyone ?
Check what you have in the device_file and device_json.
Probably it was wrongly added as a switch
In this case see what parameters are here for Fibaro and try to use same as there
That fixed it.
Thanks!
Hi!
Just bought a Neo Coolcam Flood Sensor but I’m having the same problem as you.
Don’t have a Fibaro sensor to compare the settings with.
Could you please post the settings from your Fibaro sensor?
Best regards
/Rickard
I?m also interested in the settings!!! So BUMP!
Use these Parameter Settings.
edit: Also contact CS with a ticket requesting support. They can do it as this sensor is already supported as a Dome.
On device params change:
Device_file to: D_FloodSensor1.xml
device_json to: D_FloodSensorWithTamper1.xml
And change capabilities according to the attached files
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
