[ul]Hello,
I’m new to Vera and VistaCam. I’m considering purchasing VistaCam 1100, but I’m having trouble finding enough information on it. If anyone could help that would be great!
[list]
[li]Power requirements when heating, and when not.[/li]
[li]802.3at, or 802.3af compatible? The product description and manual only mentions PoE, and that a wall adapter is included which I don’t need. [/li]
[li]Camera range of motion… The joint the camera is mounted to[/li]
[li]Camera field of view[/li]
[li]Anyone have sample images captured at night where the IR LEDs are enabled?[/li]
[li]The manual says H.264 and MJPEG are supported. Over which transports? MPEGTS? HLS? Is the device configured to connect to an endpoint and dump the stream, or do we connect to it to get access to the stream?[/li]
[/list]
Thanks[/ul]
