Need instructions for Evolve LSM-20W
I received 5 LSM-20W switches with no instructions.(CORRECTION- I didn’t see the wiring legend on the side of the switch). I believe I have the configuration correct:
Black= line
Blue= load
White= neutral
Gn= ground
Yellow= AS101 (what is AS101?)
Any help would be appreciated.
thanks
[quote=“ronross, post:1, topic:171851”]Hi,
Black= line
Blue= load
White= neutral
Gn= ground
thanks[/quote]
The AS101 is slave switch for 3 way configuration. Your color code for the switch looks right.
John
Black= line
Blue= load
White= neutral
Gn= ground
thanks[/quote]
Hi!
I have the same switches…
Your configuration is correct!
Flo
