Need help with wiring
I am at a loss for proper connection at my new residence. and I have already friend one Z-wave switch. Behind the switch there is black, white, red, and ground. When I removed the old switch the White was connected to line, red connected to load, and black connected to nothing. ground connected to ground, thats the easy one.
Any idea what configuration these need to be attached to the switch?
Also the white wire connected to load has red electrical tape near the end.
It would help if you told us where you are from. Also what switch you are trying to install.
  • Garrett
I am in the US, Florida. It is a Jasco On/Off switch. I think I need to get swtiches that dont require a neutral, but I am still confused as to why the black wire is even in the wall.
That is totally NON standard wiring … So you need to figure out which wire is which.
Is this a Romex 3 Wire + ground (White, Red, Black, and bare copper wire) ?
What is it controlling ?
Sounds like the power goes directly to the controlled device … and they use this wire to control the
switching.
If my assumptions are true … you should be able to open up the box for the controlled device and
wire it correctly (using common standards) to the wall switch.
In this case:
White - Neutral
Black - Line
Red - Load
Do you have a volt meter?
Yes I have a voltmeter, and it is a switch that controls a 4 bulb track light. The wiring seems quite odd. And yes it is 3 plus bare ground.
