Need help with VeraMate app
I just downloaded this app. And admittedly I am still new to all of this. But how do I customize my layout? How do I create more rooms and then assign my various devices to those rooms? And what is the dashboard, it’s blank?
Roughly, there’s a class of apps where the user does the design work, and another class of apps that read the entire configuration from Vera and present a UI based on that. VeraMate is one of the latter apps that auto-configure. So rooms and dashboard correspond to what you have set up on your Vera.
(When I go to the Dashboard in VeraMate, it does pop up a box explaining the feature. And that they may offer some form of in-app configurability of the dashboard in the future.)
Just as an addendum, it sounds like you may not have setup your vera yet, so I’d follow the instructions of the quickstart guide:
http://wiki.micasaverde.com/index.php/Quick_Start
That should get you started. But oTi@ is correct, VeraMate takes the configuration and displays the rooms and devices assigned to them (including the “dashboard”) via the vera box.
I just downloaded the app and my Vera is setup (since 2009) but I have a blank dashboard. Everything else looks fine.
Hi @blazinace. I’ll have to ask the obvious as I’m not aware of any outstanding issues for showing items in the dashboard, but you definitely have “pinned” devices in your setup? Otherwise, would this be a pre-UI5 controller? I haven’t tested prior to UI5, so this could be a problem if the configuration specifying whether a device/scene is pinned has changed…
I have a pre-UI5 unit. Actually its the first generation Vera.
