Hi all,
I am very new on this and I need help to get set ZXT-120 Ver 1.5 on vera lite on 1.7.439
I have Fujitus Inverter which I would like to setup on vera lite,
how can I setup, I tired following manual but issue with it is I can’t find code 27 to configure , can I get help to configure this controller
help is appreciated do any one have screen shot where I have to configure or how can I configure
Thanks in advance
Use Device Options > click Add configuration settings. Add variable: 27, 2 byte dec, <your_value>
Thanks Yevgen,
I tried config on Vera Lite as per instruction but still not able to,
Please help me to configure
regards,
Value is not saved.
Some reasons:
- Do you have off/cool/heat buttons at a ZXT pane? Make sure that vera’s f/w is 1.7.439. Previous versions have issues related to ZXT-120.
- Use mini USB adapter to power it up and then switch to always listening mode (or smth like that see manual). This should make ZXT to be a bit more responsible. Do not use batteries.
- ZWave network may be not healthy. In case you experienced disconnected device(s) problem, heal it by Settings > Zwave settings > Repair > Go. Start it overnight - it may take up to several hours.
- If nothing helps, try to set variable size to ‘1 byte dec’, or delete, reset, and add ZXT to Vera again.
I have this device working perfectly.
