Need Help on Scene Creation
Hello All,
Good day to you.
I am Leon Kho from Malaysia & I am new here.
I have question about the scene creation. I am using Vera Lite & TKB 2 Gangs switch.
  1. Is it possible to use the right paddle switch to activate a scene?
  2. Can I use the right Paddle switch to trigger a relay for 3 seconds and then release? (for auto-gate purpose)
Please advise. Thank you.
is there anyone here to help me?
I might try to help but I have only experience (basic experience !) on UI7. I have able to do simple scene like that but I can only try to help if your are un UI7
What a wonderful thing it is to be used in daily life.
I’ve not used the TKB 2 Gang Switch myself, but if the device is registered on your vera, then you can react to any status change it captures.
I assume however that you will need to power both switches, as they are intended to be used with lights. How have you got it wired?
