[quote=“integlikewhoa, post:20, topic:181053”][quote=“GoingGreen, post:19, topic:181053”]Integlikewhoa, I am not following your comment about the diagram.
“I have attached the wiring diagram below, one un molested and the other I have circled the 120 to 24v transformer and traced over the common wire as it leads down to the connection block.”
Did you forget to attach the diagram? By “connection block” I am assuming you mean the “polarized plug”.[/quote]
Today your attachments are showing clearly. There must be a bug in the forum software.
No I attached 2 files in that post and as you have found they match the one in your 2nd picture.
I’m assuming the one lower in the pic is the one going to the thermostate. The higher one is going outside to the a/c unit.
Yes, this is correct.
Are you sure it looks like in the picture the blue in the air handler is wire nutted to the blue going to the inside thermostat. Hard to tell as the red wires are in front blocking the picture.
Yes, this is the case. However, the blue and white conductors are cross connected in the two cables.
And you post one or two more pictures with the wires moved around a bit to show me which colors are going to where from both the outside ac and the thermostat
Also the way they have it wired it doesn’t look like you’ll need the 6th wire and it looks so far (waiting for pictures to confirm) that the 24C wire is already hooked up in the air handler to the blue going to the thermostat. So it just might be a matter of putting blue to the 24c in the thermostat and your done.
I specifically right now need to see better shots of the which wires are going to the outside a/c unit. The white wire coming from the thermostat (the heat wire) is wire nutted to?[/quote]
I’ll try to separate the wiring better and take more pictures. Thanks so much for your effort. The digital photos are 5 megapixel and zooming in might help.
