Need Help Finding A Switch, or a Solution
I have a four-gang outlet box on the wall with three switches and a fan control in it. I want to change one of them to a Z-wave compatible switch. The one I want to change is non-dimming, non-3-way.
But the cuts in the wallplate are for the standard narrow switches, not for the wider Decora-style switches that all the Z-wave devices seem to use. How can I accomplish this? Possibilities:
  1. replace all with Decora style switches (assuming I can get a proper fan control) and then get a 4-gang Decora wallplate. Max work, max expense.
  2. Find a narrow cut Z-wave switch module.
  3. Get the thing re-wired to a 3 gang box and 3-gang wallplate, and run the wires for the 4th switch I want to control to a separate single gang box.
  4. Didn’t there used to be a brand of mix-and-match wallplates that you could used to custom make a wallplate with different pieces?
  5. ???
Advice appreciated!
Bob (beachboync)
check for retrofit appliances…you can keep the current toggles and put the controls in the wall or ceiling (hidden)…
www.asihome.com
http://www.asihome.com/ASIshop/product_info.php?cPath=564_574&products_id=4882
Will the DSC18103-ZWUS work with CFL or LED bulbs? I would love to use this for my outside lighting.
Thank you
you have switches and dimmers in the website.
please use for cfl or no dimmable leds: switches
and for dimmable lamps and leds, the dimmers…
@beachboync - If I’m understanding you correctly, you need one of these Leviton P326-W 4-Gang 3-Toggle Decora Combination Wallplate
Thanks All. Z-Waver, that plate would work perfectly, as the switch to be replaced it on the end!
Bob
