Hi
Pretty new at this.
I got a s412 switch mountet on the wall. Whe I press one of the buttons it lights up. Have to create a scene that works when I press a button.
[url=https://www.tronika.no/1767-large_default/bryter-s412-touch.jpg]https://www.tronika.no/1767-large_default/bryter-s412-touch.jpg[/url]
So I have downloaded the PLEG and PLG pluggin. Created 2 logic inputs. One that set a condition for garagedoor open and other for closed.
I want to create 2 scenes for when I press the button.
If I turn on the button on the switch then run PLEG to check if garage door is closed. If closed then open garage door.
If I turn off the button on the switch then run PLEG to check if garage dorr is open. If open the close garage door.
How can i create this scene for the s412 switch?
