I just upgraded my Vera 3 from UI5 to the latest UI7. The upgrade went fine, and I am now greeted by the UI7 dashboard. I’ve somehow lost all my settings, but I’ll get over it.
The problem I have is instead of a page opening locally, it goes online for me to select the controller, and then just returns to the dashboard. For instance, I click on “Login”, and it then goes to my units at getvera, I choose the unit and then it just goes back to the dashboard where I can keep repeating this loop. The same exact loop occurs when I click on “Users and Account Info” as well as some of the choices in the “Settings” section.
Can anyone suggest what the problem is?[/quote]
As weak as “clear your cache and cookies” sounds, it may be the answer.
Thanks for the advice! I went to bed and kept setting it up on my phone, and that way worked. When I got up I cleared the cache in my browser before I tried accessing Vera and then tried it and it worked.
Sent from my HTC One_M8 using Tapatalk
