I’m having problems getting events to work with an ACT euro motion detector and appliance unit (ZIR010 and ZRP210). The ZIR has a sticker on it saying release 1.1
These are the steps I have been through:
I started with all devices powered off and a virgin Vera.
Switched the Vera on and allowed it to update to the latest firmware which went fine.
Got to the section ‘add devices’ and added the motion and appliance devices - had to first reset them with the dongle before they would be included as they were previously part of my old network.
Using the automation section I created an event:
Type: “a sensor (door/window/etc) is tripped”.
What: motion detector [Lounge]: “the sensor is tripped”
Chose the appliance device and told it to switch on and after 10 seconds switch off again.
I saved the changes and then pressed the ‘Go’ button and sure enough the appliance device switched on and ten seconds later switched off.
I then walked in front of the motion detector, the led blinked but nothing further happend.
I looked at the documentation for the ZIR010 (http://www.act-solutions.com/HomePro/pdfs/HomePro/Inst/ZIR010_instr.pdf) and found that it has three modes of working: Lighting, Alarm and Binary Sensor. I have the ACT hand remote so I can send config information to the motion unit and I tried all three variations but still no success.
Just to make sure all was working between sensor and aplliance unit, I set them up to switch on and off independent of the Vera. I used the associate function on the remote control. This worked fine with the motion detector set to Lighting mode.
I then reset everything and set it all up again to see if I had missed anything - but still no success.
Any ideas where I go from here ?
On a side note but with reference to an earlier post in the forum, the ACT docs say the motion detector waits for two minutes of inactivity before going idle if set to either Lighting or Binary sensor mode. There is a configurable delay AFTER the two minutes by adjusting parameter 18. Is two minutes the absolute minimum or, as seem to be suggested in the earlier post, can it be reduced. Testing a motion detector and having to wait two minutes between events is a pain in the proverbial
