MyVera, Web interface for the Vera - now in English
Hello,
I created this thread on MyVera on the occasion of the passage in English of this interface.
It come as a supplement to the topic created by Psykokwak where he explained how to install MyVera directly on the Vera.
MyVera is an interface that allows you to control your home automation from your browser (chrome or safari only) or from a tablet or smartphone (ipad, iphone or android device).
Here, some screenshots :
And a video : Interface domotique sur iPad - YouTube
You can download it from my blog website : http://sbdomotique.wordpress.com/myvera-dowload/
Here is a FAQ (in French) : MyVera – Le FAQ | SB domotique
The official MyVera thread (in french) : TouteLaDomotique.com : la maison connectée au meilleur prix
This interface uses PHP, so you will need to have a web server with PHP that can communicate with your vera.
Psykokwak proposed a solution to put a server php directly on the Vera but you can use another solution (a NAS for exemple).
The translation in English was realized by zolakk. By default, MyVera is in French.
To translate MyVera into English you have to replace the file resources\locales\lang.json by lang_en.json.
I’ve just installed MyVera on my apache2/php5 webserver and after giving write permissions to the protect/config directory it sprung to live. But I do not get any scrollbars using latest version Safari on OSX Mountain Lion, so I can not save any modules. Is there something I am missing?
Hello,
By default, MyVera is for touch-screen, also you have to slide with the mouse to scroll (as if it was a finger…)
Envoy? de mon iPad ? l’aide de Tapatalk HD
Ah! That works perfectly :smiley:
Looks absolutely fantastic, my compliments.
Hi Sb_Domo,
Great job… Works fine, now in english… :wink:
For alls:
Please make a donation to developer by paypal…
Luis
Hi sb_domo,
Thanks for this great app!
Is there a way to go directly to the “Dashboard” tab when opening MyVera?
And is there a way to hide the the tab to the left of the dashboard?
Also, when I modify the text color or size of modules, this never has an effect. Even after saving and reloading the page.
I am using build130324b1.
Hello tvdnagel,
If you want go directly to the “Dashboard” (in Landscape and Portrait position), in the “General Config”, put off the “Landscape View” and “Portrait View”.
You can’t hide the tab’s view.
The color and size parameters are for views, not dashboard.
The text color is for the text under the icon. You can change it, click on update and save your list. It must be work…
For the size of icons :
In Retina mode, you have to write the size you want to see (50px by default for 100x100px images).
In non retina, the size is the size of your icon’s image (50x50px by default).
Thanks sb_domo, that clarifies the situation!
This is definitely an awesome tool to use on a tablet! I used SweetHome 3D to design the layout of my house and it is all working well!
I have a question about the HVAC though. It detects my thermostat as an HVAC unit which only displays a circle with a “?”. If I change the category of the device to a “Smart Virtual Thermostat (Plugin),” I do get a prompt when I click on the icon in the layout of my house. The values show as Fahrenheit which is correct for my location but as soon as I click on the numerical temperature field, it goes immediately to 35 as the value which I assume is Celsius. Is there a way to use this as Fahrenheit? Initially, it reads the value correctly so it shows 73 degrees in the box but as soon as I click on it, the number changes to 35 as the max value…
This looks quite interesting and I have it installed. However, I don’t have my VeraLite password protected, so what do I enter for username/password? Or is this to protect MyVera? Unfortunately Google Translate didn’t really help with the Readme!
Thanks.
[quote=“sgruby, post:10, topic:174720”]This looks quite interesting and I have it installed. However, I don’t have my VeraLite password protected, so what do I enter for username/password? Or is this to protect MyVera? Unfortunately Google Translate didn’t really help with the Readme!
Thanks.[/quote]
I just typed in a “new” username and password and as long as my IP address field matched the Vera device on my network, it works! I’m not sure if the username and password field is there for the myvera application site or if it functions with a Vera device that has been configured to require a logon when using the internal network. In my environment, it doesn’t appear to affect anything!
I solved my own problem; php wasn’t running on my server. I’ve fixed it and I’m good to go.
Thanks for the quick reply.
Hello,
I’m happy you think MyVera works well.
The uesername/password is use to protect the acces of MyVera. if you have not protect it, you can use what you want…
Hvac is not compatible with MyVera at the moment (just because I don’t have it any to test). Perhaps it could works as a Virtual Thermostat, I don’t know. For ?C/?F, I think that one of the problem is to be able to change the start and end numbers of sliders. I do that in a future release…
I’ve installed MyVera on my WAMP-php server, the interface starts up, I enetered my login info, and it populated the rooms. Then I get an error-Error No response in sync. Try again?
Any ideas?
Thanks,
Rob
Hello,
I don’t use wamp but here some clues:
What version of php did you have ? (Json’s functions must be implemented)
Curl must be activate.
The php commands must be able to write in the file and directory of MyVera…
Php is 5.3.13
Write access is allowed.
I’ll check on curl
MyVera is great add-on to my VeraLite. Im running it on my Android phone which is allways on in my home and also has sms server for Veras notifications. MyVera shows temperature sensor values correctly but in instead of Celsius symbol it shows Fahrenheit symbol. How can i change that?
I had the same issue, I ended up changing it manually in the lang.json file under \resources\locales\
Here is the swedish language file if anyone is interested. (not perfect, but a good start)
/Mike
Hi SB_DOMO,
I have installed MyVera , great work, so nice and easy to use,
I have a first question about your interface - what about the NEST , is i working with Myvera?
Areb65
