I just dont get it… tried to reboot also… same result…
Any idea ?
I tried deleting other devices just to see… I was able to delete them. Except for device 41 witch is a Mimo from fortrezz … is it related, I dont know…
Any idea ?
All help appreciated.[/quote]
Check the parent device under the advanced tab. If these are actually unwanted devices set the parent to 1 (the zwave controller) and then try to delete. At least I’m fairly certain this is what I did when I had a few of them pop up.
Ah, thank you so much! Somehow I didn’t know about this trick… Setting “Parent device” (id_parent) in the Advanced tag to 1 resolves the bogus device problem!
