Hey guys. New to Vera, running UI5. I’ve built the Mysensors serial gateway and it works great unless the unit is rebooted (or lose power and it comes back up). It appears that the USB device is not being recognized. I can get it to show up if I remove the usb device then replug it in. I then have to go and set the baud rate again on the serial port and then things start working as they should. As you can guess, I don’t really want to do this any time the device reboots. Does anyone have any suggestions on how to get a persistent connection?
This is a known problem , The ethernet gateway doesn’t have this problem.
Cor
Noted. Thanks… I’ll build the ethernet gateway then.
