My Vera lite is 90' from my Kwikset lock
I can only control the lock when it’s within a few feet of the Vera Lite. However my front door is 3 floors and about 90’ from the VL. In this location I can control the Lock anymore, any suggestions.
You need other zwave nodes between the door and Vera, and at least one device near the lock that supports beaming/hail!
If you have this, then you perhaps you just need to perform a heal!?
[quote=“strangely, post:2, topic:173921”]You need other zwave nodes between the door and Vera, and at least one device near the lock that supports beaming/hail!
If you have this, then you perhaps you just need to perform a heal!?[/quote]
I have nothing in between the two. I’ve just purchased a lamp module and range extender from lowes (Iris/GE-Z-wave) will this work? Also what do you mean by perform a “heal” sorry I’m a newbie :slight_smile:
http://wiki.micasaverde.com/index.php/Heal_Network
Most likely you won’t be able to control the lock reliably unless you have some intermediate nodes to create a mesh. Try it out anyway.
Thanks that was helpful. Any suggestions on what type of device I should use and their spacing?
Please do a search on the forum. This topic has been discussed many times and you will be able to find your answers by doing a search.
  • Garrett
