Does my sensors plugin work with vera3 running on ui7?
I have seen no mention of it but maybe you have.
I think that the majority of my sensor developers are smart enough to steer clear of UI7 for now.
[quote=“5546doug, post:1, topic:183513”]Does my sensors plugin work with vera3 running on ui7?
Thanks[/quote]
I agree, nothing but problems in UI7 for now.
We will offer our full support to developers that require our help for migration process. For anything related,please contact us :
Related topic:
http://forum.micasaverde.com/index.php/topic,27645.0.html
[quote=“mcv.johnm, post:4, topic:183513”]Hi,
Related topic:
[url=http://forum.micasaverde.com/index.php/topic,27645.0.html]http://forum.micasaverde.com/index.php/topic,27645.0.html[/url][/quote]
I think you guys have your hands full at the moment.
Let’s get u1.7 even remotely stable with just the basic plug-ins, before I think about making ANY moves.
[quote=“ServiceXp, post:5, topic:183513”][quote=“mcv.johnm, post:4, topic:183513”]Hi,
Related topic:
Let’s get u1.7 even remotely stable with just the basic plug-ins, before I think about making ANY moves.[/quote]
Please note that all documentation needed for plugin migration to UI7 is available. For basic plugins, usually minor updates are required : changes needed for icons and maybe some other modification depending on each plugin. A little more work is required for plugins with JS, but you should find now almost everything you need for updating your plugin. Check Official Announcements thread for links to UI7 documentation. You will find there a plugin example too. Also you can check the WeMo plugin for another example.
And finally, if you have any other issue or question, you have my contact details. It is true that we have a big “to do” list, but if we offered our support to developers, then try to take advantage of it.
Best Regards,
