My Hawking HRDS1 window/door sensor shows up as a motion controller
Did a search but couldn’t find an answer…
When I configure Vera to see my HRDS1 window/door sensor - Vera sees it as a motion controller. When I try to program scenes however it won’t come up under window/door locked/unlocked.
Anyone know how to manually configure this device? Or how to change the configuration once Vera finds it?
Thanks, -jd
Vera sees the window/door sensor as a motion sensor, so you have to use “sensor tripped yes/no” for your scenes.
