My first experience with Vera Concierge... Not working for me.
So happy that work is being done on connecting to google assistant!!! Please keep it up.
Version: 1.013
Me: “Ask Vera Concierge to turn on my Pantry Light”
"Executing turn on the pantry light… What Else?
Nothing happens.
Me: “Please Turn on Tv Light.”
“Sorry I did not understand that!”
Me: Any command at all
Above is from google, my activity. The home unit will start the concierge and claim to execute the included command, but after that, does not understand me. Did I do something wrong or leave out a step?
Please try:
talk to Vera Concierge
And see if it recognizes your Veras.
Do you have more than one Vera ?
What is your Vera serial # I can look at the logs.
When I say talk to vera concierge
The response is…
“I can help you command and check that status of devices connected to your vera controller.”
Any command I Give
“Sorry I did not understand that.”
My serial number is 45024979
OK … I have to build some debug tools …
Everything in the Google Database (where my cloud server runs) is encrypted (For your protection!) … and it makes it impossible to debug.
[quote=“reedpage, post:1, topic:196172”]So happy that work is being done on connecting to google assistant!!! Please keep it up.
Version: 1.013
Nothing happens.
Above is from google, my activity. The home unit will start the concierge and claim to execute the included command, but after that, does not understand me. Did I do something wrong or leave out a step?[/quote]
Which Vera UI version are you running? I’m having no luck with UI7 and am about to downgrade to UI6 to see if I can get it to work.
Yeah, I’m using UI7, so that could be an issue.
Yeah. I was hoping this app would support UI7, but it seems that it’s one of many apps that don’t.
I’m running UI7 on a Vera lite and it’s working for me… I’m running the jar service on a Windows 7 pc.
Interesting.
When you go here and click on “Local Concierge Server Connectivity” https://veraconcierge.appspot.com/web/Account , what do you see?
It looks like it returns the IP address, name, etc of the Vera and the Google cast devices I have. I did have to set a name for my Vera before it would work. Do you show a name in the Concierge? It was a nickname in the Vera UI I believe to set it.
