I am currently using a vera lite and a vera 2 (from two different locations) each running on UI5. I have schlage locks and lever pairing with these vera systems. they have been up and running for 2 years now and working flawlessly.
I own 3 vacation homes and assigned specific codes to different users. The COA, the cleaning crew, and guests each have different codes. I can track the time and date they are accessing the door but what I cannot figure out is how to find out which user is accessing the door. I go to “Logs” ==> then “My alerts” screen appears and I can see the time and date but how can I tell who is entering the code. Please tell me what am I missing???
I have another schlage lock pairing with vera 2 but ruinning on UI4. Now on that system, there is a log and there, I can tell which user is accessing the code.
Sorry for reviving an old post, but I’m having the same issue. I have searched the forums and have yet to find an answer. Surely the access PIN used is logged somewhere, right? I’d hate to think the only data I have available is the time and date of entry…
You don’t have to check the checkbox for notification of any user. Even without the checkbox you will then see 2 entries in your “My Alerts”. First the door unlock/lock event and right after that the Pin code with the name you have given it e.g. “Cleaning Crew”.
Thanks! I guess I should have been able to figure that out. It just seems like there would be a simple log file that you could review that will tell you at a glance the pins that were entered and the time.
