Multiswitch function?
I have Tasker, Autolocation, Authomation HD on my Android phone.
Does Authomation allow control of multiswitch?
I have set up a geofence via tasker and it is working correctly. Now I want to create a task that will simply turn on multiswitch 1 and turn off ms 2 when inside the fence, and turn on switch 2 and turn off ms 1 when outside the fence. Then I plan to use PLEG to take over to do some automation things.
Anybody do this? Can you show examples of your tasker setup please? I am a noob with tasker!
I cannot use Richard’s Vera Prox as it requires Google which is not usable in China.
Currently only the alpha version of AutHomation supports the multiswitch. So if you are not running the alpha version, you will not be able to use tasker with the app to do what you want to do.
  • Garrett
I was in the same position, I found a lot of ideas for tasker here:
[url=http://androidforums.com/tasker/158265-what-tasker-profiles-everyone-using-thread-not-requesting-help-profiles.html]http://androidforums.com/tasker/158265-what-tasker-profiles-everyone-using-thread-not-requesting-help-profiles.html[/url]
and some basics here:
[url=http://www.pocketables.com/2013/03/overview-of-pocketables-tasker-articles.html]http://www.pocketables.com/2013/03/overview-of-pocketables-tasker-articles.html[/url]
Garret,
I have installed the AuthomationHd, and virtual thermostat and multiswitch don?t run.
Regards
First the virtual thermostat is not supported currently in the app. Second, you’ll need the alpha version of AuthomationHD. The play store version does not support the Multiswitch plug-in. Only the alpha version that can be found in the alpha thread of this sub-forum.
  • Garrett
