I’m still pretty new at this stuff myself but I’ve finally had a chance to get my hands dirty these last few days. I believe if you use multiple scenes with the same trigger it wont be 100% reliable as it’ll be a boat load of zwave traffic and from my understanding scenes are just sent once. If the nodes don’t get the message oh well.
Events (as in the Programmable logic event generator (PLEG)… and program logic core plugins) will continue to run until things are the way they should be. It took a few days of reading before I decided to try it out but worked perfect. The language used is much more intimidating than the interface but offers way more options the vera by herself.
Vera = OR logic only = if door open OR its 9pm turn light on ← either one by itself will trigger the action
PLEG= AND = if the door is open AND its 9pm AND … … … then turn the lights on <— all have to be true to trigger
but PLEG isn’t just AND logic… its really all logic expression… you can pretty much use anything as a trigger
I set up an event so when someone opens the basement all my hue light bulbs change to RED then back to normal after 10 seconds… normal being whatever state it was in before… cant do that with normal UI
If you need help let me know… it took far too long to figure this stuff out… it seems just too far spread out. maybe I should make a youtube video. Probably too lazy :-X
